C4 - Hard barking peddal updates - findings - need help
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
Hi
Car is Citroen a petrol C4 1.6 with auto gearbox ( AL4)
Some updates to the following thread
http://www.frenchcarforum.co.uk/forum/v ... =3&t=55504
The hard pedal happens only when the car is stopped and the revving at around 800 RPM.
In order to sort this I took the car to a certified Citroen garage ( never before go to a certified garage but as it is wife's car I wanted a fast remedy ) . They did the following things that didn't help
1) Replaced the vacuum hose ( part number 457884)
2) One way valve ( part number 459931 )
3) Replaced the brake amplifier ( AKA booster )
Than they replaced two valve hydraulic lifters ( part number 94293 ) that according to the garage were a bit seized, called me and say that the problem is sorted. They also claimed that this is due to dirt in the oil system and suggested to flush it. Happily I went to take the car. I checked it and it looks better. Two hours after I parked the car, I had to drove it and the hard brake pedal is back.
I did some more checking and here is my findings ( N is gear in Neutral , D gear is in Drive ) :
A) When the car stops and the N is engaged the brake pedal is almost normal, when pressed it travels around 3/4 of the full travel. Staying in N and revving to 1500 and up the brake pedal when pressed travels all the way
B) If then the D is engaged and I release the pedal brake and press it again it is rock hard. So it looks that when the engine is under load ( engaging the D ) the vacuum to the brake amplifier decreases results in hard braking pedal.
C) I measured the cylinders compression pressure , two cylinders read 170 psi and two 130 psi.
Can the low compression pressure affect that dramatically ?
I guess the above is related two my thread http://www.frenchcarforum.co.uk/forum/v ... =3&t=55642. Regarding this thread the as Simon suggested they say that the cause is a failed torque converter . Can a failed torque converter be the cause for the hard brake pedal or it is more likely the engine is weak ?
Zohar
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
x 1471
Re: C4 - Hard barking peddal updates - findings - need help
Unread post by xantia_v6 »
I would not think that a torque converter fault could affect the brakes, but Simon's suggestion of a blocked catalytic converter (causing low vacuum at idle) could be a sensible explanation.
lancia58
(Donor 2022)
x 8
Hi
If the cathalytic converter is blocked how comes that when the gear is in N the vacuum is OK and when in D the pedal is hard ? The car past the mot in January with no problem. I took the car to an exhaust specialist and he said that the air flow is OK i.e. no blocking. Having said the above I suspected the cathalyticc convertor and I am not sure that the above contratdicts this. Is there an easy way to check out the cathalytic convertor ?
Regards
Zohar
x 1941
Unread post by Paul-R »
Does the car have an electric parking brake? I notice on my C5 that the pedal goes hard after the parking brake operates.
lancia58
(Donor 2022)
x 8
Hi
No it doesn't have an electric parking brake
lancia58
(Donor 2022)
x 8
Hi
Any ideas ?
Zohar
demag
x 102
Unread post by demag »
My son had a Peugeot 306 1.9 DW8 with a blocked catalytic converter and it wouldn't run. There was just too much back pressure.
Sent from my Wileyfox Swift using Tapatalk
Dave
