Lexia 9780.Z5 has gone home.
Edhertz
x 5
Unread post by Edhertz »
Looks like my Lexia 9780.Z5 diagnostic tool has gone home. It all began when I hooked it up to the Xantia and found that it was unable to have a dialogue with the ECU. The operating light was on on the tool and seemed to be working o.k. I tried it a few more times and in the end hooked it up to my Pug 206 to see if it worked there. Result was complete failure to communicate with message ' Comms interface is not connected to USB port'. No light on device. Tried it in other laptop and not recognised in any USB port, so looks like a dead parrot. Has anyone out there had the same problem and where would you go for a replacement?
Thanks in advance
Alan
1999 Xantia Exclusive 2.0Hdi Mauritius blue
1999 Peugeot LX 1.9D silver
x 8411
Re: Lexia 9780.Z5 has gone home.
Yes, seen the same happen a few times now unfortunately...
Sadly it's now useless unless it's something simple like the cable has gone open-circuit... I'd certainly check that before declaring it truly dead...
I did look at a duff one but there really is not a lot to be done... 'No user serviceable parts inside' means what it says sadly...
Edhertz
x 5
Thanks for your comments Jim. Checked connector/cable for continuity and is o.k. Where would you go for a replacement?
Alan
x 8411
Not a clue where you'd get a replacement from I'm afraid... Sorry..
