Limp home mode
bc2000
Limp home mode
Hi, I was wondering if anyone has a solution to this. My pug 807 Executive, 2l petrol automatic keeps going into limp home mode. There is usually a clunk and the display will say "Automatic gearbox faulty" and it will go into limp home mode. All I have to do is switch off the engine and switch on again and it will be fine till the next time, which could be 2min or 2 days. There doesn't seem to be any pattern, it can happen after 5mins or 30mins, at low/high speed. It does always seem to happen on motorway slip roads just as you join the motorway. I used to stop on hard shoulder but sometimes it would do it again. If I drive for a while in limp home mode then restart it tends to be fine after that. My local mechanic can't find any fault and I had the gearbox oil changed and it made no difference. Help!
spider
- x 77
Re: Limp home mode
Lexia (Planet) diag will show the real fault here. Other / general diagnostics may not as it could be a manufacturer specific code.
Note: The replacement oil was the correct one was it ??? They will suffer (very!) badly with the wrong oil in them aka: General ATF.
One fault I saw recently on a 207 (same transmission) the cause was actually the selector switch on the gearbox, the plus was a bit corroded. Once this was cleaned up (bit of a pain to do actually but cheaper than a switch!) it was fine.
Andy.
bc2000
Re: Limp home mode
Thank's spider.
The oil replacement was done by Mackie's in Glasgow, they are specialists in automatic gearbox's so I would imagine they used the correct oil.
Is the selector switch hard to check?
I was hoping it was a problem with a sensor. It's been doing this for 2 years so if there was a real problem I imagine it wouldn't have lasted this long.
Again thank you for your time.
- x 1996
Re: Limp home mode
Never BET on thatbc2000 wrote:Thank's spider.
spider
- x 77
Re: Limp home mode
Its kind of detailed in the Haynes but diag will be more accurate as that should indicate the positions correctly.
To get at it, its not bad but its a bit fiddly. Basically:
Battery out
Battery tray out ( a few bolts )
Selector cable off (you'll see this once the battery tray is out)
The switch is sat on the selector 'arm' , a vertical shaft.
If you are going to remove it, please please make a small mark on it and the shaft so it goes back in the same place as the bolt holes are slotted a bit to allow for a bit of adjustment. If its in the wrong place it will cause issues.
Battery out
Andy.
- x 1459
Re: Limp home mode
Mackie's should know what they are doing, they are the people who recondition 4hp20 torque converters.
The only way to check the switch is to have the car connected to a Lexia, which would give you the fault codes anyway.
