Xsara Picasso front left knocking noise
Oliver53
Unread post by Oliver53 »
53 Picasso, when going over bumpy roads I get a knocking noise from the front left area, it feels just behind the glove box. it happens also when I rock the car. But not when accelerating, braking or turning. The sound is kind of "gentle", just like a loose plastic box is hitting something. Car drives normal, apart from slight vibration of steering wheel at about 70MPH, which I thought was due to bad balance of wheels.
Any ideas?
2000 ZX 1.4i
2006 Xsara Picasso 2.0i
2011 C5 2.3i (EW12A)
2003 Xsara Picasso 2.0HDi
1985 2CV6 Special
x 1240
Re: Xsara Picasso front left knocking noise
Unread post by Peter.N. »
I would suspect its a anti roll bar drop link.
Oliver53
Peter.N. wrote:I would suspect its a anti roll bar drop link.
Thanks Peter. Will be driving to ICCCR on Friday, I'll try to have a look at drop link tomorrow.
2000 ZX 1.4i
1985 2CV6 Special
x 1504
It does sound like a drop link - however, the 3 bolts holding the strut are not the same length, and if the short one is not put in the right place, the spring can catch on it and cause a knocking noise. So if the strut has been out, worth a check.
chinkostu
x 30
Unread post by chinkostu »
Definately sounds like a droplink to me. the rocking of the car making the noise kind of points to something on the roll bar, as you're loading each side of it up in turn!
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
Oliver53
I can feel quite a lot of play of the near side drop link by hand while wife is rocking the car. The other side is fine. Have no part in hand and tomorrow at 6am will be setting off for ICCCR...I may find someone at the site to get it done then. Should be fine right? What a relieve it's not top mount, lower ball joint or other key things need doing. Many thanks for your kind suggestions guys.
2000 ZX 1.4i
1985 2CV6 Special
Oliver53
Just an update, it was the drop link needed replacing. No more noise after a new TRW part was fitted:)
Many thanks for your help guys.
2000 ZX 1.4i
1985 2CV6 Special
Due-due
Unread post by Due-due »
RichardW wrote: 11 Aug 2016, 09:05 It does sound like a drop link - however, the 3 bolts holding the strut are not the same length, and if the short one is not put in the right place, the spring can catch on it and cause a knocking noise. So if the strut has been out, worth a check.
I have heard this too, Richard. Two are of the same length and one of shorter length. Where does the shorter one go again, please?
x 1504
Although I understood it to be the case, the parts database doesn't bear it out, and just lists all the bolts the same length - 16mm for normal suspension and 20mm for heavy duty. It may have been that the factory fit bolts were unequal length, as the replacement parts are not always the same as the factory fit.
Due-due
RichardW wrote: 10 Mar 2024, 18:37 Although I understood it to be the case, the parts database doesn't bear it out, and just lists all the bolts the same length - 16mm for normal suspension and 20mm for heavy duty. It may have been that the factory fit bolts were unequal length, as the replacement parts are not always the same as the factory fit.
Ah, ok. Thank you for your reply.
