Peugeot 406 D9 Gearbox 4Hp20 Problem
zeerk
Unread post by zeerk »
Hello,
My first post here ,,, :roll:
Recently I Bought Peugeot 406, D9, XFX with faulty Gearbox, imported from Switzerland to Libya
after inspection i found that the gearbox died due to wrong oil used and the gearbox was overfilled
so I purchased used C5 4HP20 and fixed it in to my car without inspecting the Gear and final output ratios
after driving the car it has harsh gear change with bang and jerk
after searching a lot i found that i have fixed wrong gearbox but not sure
these cars are not common in Libya and it is not possible to get the same gearbox
my gerabox code 037
C5 donor gearbox Code 054
any suggestion or help will be appreciated
and sorry for my bad English
zeerk
Re: Peugeot 406 D9 Gearbox 4Hp20 Problem
any suggestion which codes are direct replacement of 037 ???
x 1460
Unread post by xantia_v6 »
If the replacement gearbox came from a car with a similar engine, then it is possible (but not guaranteed) that fitting a transmission ECU that matches the transmission could fix the problem.
x 1996
Unread post by Stickyfinger »
Not a clue about the box....but Hi and Welcome to the forum
zeerk
Stickyfinger wrote:Not a clue about the box....but Hi and Welcome to the forum
Thank you dear
zeerk
xantia_v6 wrote:If the replacement gearbox came from a car with a similar engine, then it is possible (but not guaranteed) that fitting a transmission ECU that matches the transmission could fix the problem.
ok i will check if I found the TCU from where i bought the gearbox
and many thanks for your suggestion
zeerk
my bad luck ,,, couldn't find the TCU from the donor
is there anything i can change from old box to new one ??
Please Advise
toh
x 5
Unread post by toh »
Have you checking well all sensor on 4HP20 ?
what about ECU of 4HP20 ? Does it work ECU of engine ? I mean there is a map between engine ECU and gearbox ECU. One model of engine ecu works with one of gearBox ecu.
Let's show a model of your engine and gearbox ecu..
LOVE is All AROUND.
x 1460
zeerk wrote:my bad luck ,,, couldn't find the TCU from the donor
Please Advise
We know that the transmission ECU will throw an error if the gear ratios are wrong. In the case of my old Xantia V6, the transmission was inadvertently rebuilt with a differential gear set from an HDI, and that caused similar problems, so I think that you should try and get the right gear sets. I don't know whether there are other transmission components that the ECU can detect, I suspect not.
