Car has only 150,000 miles on the clock, so as its only just run in, i'll be able to start thrashing it soon.
Went to Citroen this morning got 4 diesel injector washers, removed the offending diesel injector, swapped it for a "claimed good replacement diesel injector" after using a injector seat tool to clean the base, installed injector number 1 tightened up clamp bolt to 30nm, thought happy thoughts started car and it fired up as it used too without any hassle!
Glad its running as it used to now rather than take 5 or 6 seconds to catch and fire up. Only thing i noted when lifting the bonnet was it was wet with diesel around the pipe union so nipped that up and will see later.
Could i ask if 1 bad injector would send the car into "shutdown" and prevent it from starting as well as generate low fuel pressure error codes and immobiliser fault codes?
