Hi Peeps,
any advice on where I can get hold of a second hand diesel tank for my Safari - apparently it's 'weeping'... and if I can't find one - so will I be...
OLIx
Another Parts Hunt for my CX
- x 2006
Re: Another Parts Hunt for my CX
oli_25_uk
I should have been clearer (I don't know if it makes a difference) - It's a diesel...
oli_25_uk
... and given that it's just flown though the MOT I really would like this to be sorted... It's embarrassing having a car that leaves puddles (even if they are tiny)...
ekjdm14
- x 269
Leaking fuel yet it flew through the MoT???? or is this something that's developed since the test?
Either way, I'd suggest that if it's leaking along a seam and not pinholed/weakened by rust at the bottom then a good tank sealant would be the best route forward. If it does have a rusty bottom, depending how bad it is, you could get it patch-welded up despite it's use as a fuel container just make sure it's thoroughly emptied of diesel and either flooded with water or welding gas prior to making any sparks. Once strength is restored the sealant is a good idea anyway to help prevent any future deterioration.
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
