Self Fit Cruise Control Kit - Any Experience
Bargeman
x 8
Unread post by Bargeman »
Hi
I know it's getting long in the tooth (17 yrs and 135 k m) but when we use the Xantia 2 l 16v auto (Petrol) it is generally for hundreds of miles on quiet night motorways, so I'm thinking of fitting a Rostra 250-1223 Universal kit from the USA.
Has anyone any experience of fitting one or any other type, or any reason not to or things to watch for?
Hope someone can help.
Bargeman
c.morewood
x 55
Re: Self Fit Cruise Control Kit - Any Experience
Unread post by c.morewood »
Paul, citroenxm did a cruise control fit to the late xantia he had a few years ago. You could try PM ing him.
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
x 1484
Unread post by xantia_v6 »
I think Paul's was an HDI which already had fly-by -wire cruise build into the ECU, just needing switches and wiring to make it work.
You could consider fitting the Hella cruise system that was fitted to Xantia Exclusives, but you need to find a donor car...
Zelandeth
x 1613
Unread post by Zelandeth »
Having had a look at that kit I certainly can't see any reason that it wouldn't work.
Just keep in mind that getting cables between the cabin and engine bay can be a right pain on the Xantia - though I do believe that one of the big multi-way connector does have some pre-wired "vacant" pins intended for (presumably dealer fit) accessory installations.
Current fleet:
07 Volvo V70 SE D5, 89 Ford Thunderbird, 85 Sinclair C5, 84 Trabant 601S, 73 AC Model 70, 62 Rover 110.
teuski
x 11
Unread post by teuski »
I have once fitted a Rostra cruise to a 1.8 16V S2 and a VDO unit to a 1.9TD S2. Both were cable operated. It was fairly easy. If i remember right r
I have scanned the key parts of installation instructions and also some model specific install guides but they are unfortunately in Finnish. Maybe they are of some help anyway, at least you can figure out the setting for a Xantia like pulse type and speed etc. I can also help with translating.
The things to set up with a 1.8 16V are: sensitivity: high, VSS=5000 pulses, open circuit, centering slow, VSS signal type square wave,
Speed signal can be taken from a free connector under the little storage space behind the handbrake, pin 11. They suggest putting a 5,6Ohm resistor to the VSS wire.
RPM signal is on the OBD connectors pin 3 (green wire 95)
My Rostra kit was used and already fitted with Citroen control stalk. That finnish Xantia guide also has guide for wiring the OE stalk for Rostra.
http://www.citikka.info/gallery/Manuaal ... en-ohjeita
thorter
x 44
Unread post by thorter »
I fitted a Zemco cruise control to my Xantia HDI quite a few years ago, and it is still going strong. Unfortunately, I have forgotten many of the details.
The actuator is electrical via a motor and clutch, and it uses a cable and ball chain. I fitted it under the dash with a shortened cable to pull directly on the throttle pedal. Care needed to be quite sure nothing can catch or jam!
The electronic unit is in the centre console. I used the signal from the gearbox speed sensor, buffered it, and it proved compatible without further processing (normally fed from magnets on the drive shaft and sense coil).
I fitted master off switch which has warning light, and made up switch lever beside the steering wheel (up=engage, down resume, pull towards you=disengage, up or down change speed once engaged). Also, it uses brake light signal and clutch signal to disengage as normal; I made clutch switch so that a light touch disengages before any pedal movement.
With this implementation it is very easy to disengage without any change of speed. As the throttle pedal moves with cruise operation, you can shadow foot over it, then disengage with a light tap on clutch, giving seamless transition to manual.
Insurance company were unhappy about DIY fit, but did accept it. Could be worse nowadays!
Fred
Bargeman
x 8
Hi All
Thanks for the input, all useful, if anyone else would like to comment I would be grateful. I will ponder the idea over the summer as I am afloat on the French Canals until Autumn, so won't do anything till then at the earliest.
Paul (Bargeman)
