heat shield
froggy
(Donor 2026)
x 4
heat shield
Unread post by froggy »
Hi, feel a bit of a pratt! just replaced the hand brake cables on my S2 Xantia . can not see how the heat sheild fits! :oops: would anyone have an image [-o<
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
Mandrake
x 695
Re: heat shield
Unread post by Mandrake »
I don't have an image, but what's the problem you're having ?
Depending on the size of the cat it can be quite difficult to get the shield back in place - I find I have to bend it quite a lot to manoeuvre it up over the cat then bend it back again. Also from memory the front section of heat shield should tuck under the edge of the rear section.
After that it's just a matter of lining up the mounting holes with the mounting bolts so that the spring clips can be refitted...
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
froggy
(Donor 2026)
x 4
Re: heat shield
cheers thanks
Terry
