LHM PUMP QUEREY
DublinChris
LHM PUMP QUEREY
Hi all back again with another query!
My pump seems to be getting tired. Car is slow to rise in the mornings and sometimes after stopped for short time it can take longer than usual to pressurise. I have been told that it is wear in the pump and I am looking to change it. I believe it is a 6+2 pump. Car is series 2 1.9TD
Question is - is there an recondition/exchange option or is it a new pump? I believe they are pricey? Anyone got any ideas? Anyone know a part number so I can look on line?
Thanks in advance
DublinChris
Thanks in advance
DublinChris
Let the good times roll
current every day 1998 Xantia turbo diesel 1905cc series 2
- x 6957
Re: LHM PUMP QUEREY
Do you have your VIN handy so we can check the parts...
DublinChris
Re: LHM PUMP QUEREY
VF7**************[VIN obfuscated, can be read by forum staff] - It was registered Jan 1998 so probably a 1997 build date. Xantia 1.9TD, series 2 Thanks. 213000 miles as of today
- x 6957
Re: LHM PUMP QUEREY
Ok, got it, it's the 4007 T7. That's great mileage too!
Found a link to a new one here Mapco Xantia Pump
And a load from about the place Here
DublinChris
Re: LHM PUMP QUEREY
thanks for that information. I had actually come across those ones - the Mapco one seems closest but its £300+ which when converted to euro is still high despite Brexit!
With the correct part no I'll do some more searching
- x 6957
Re: LHM PUMP QUEREY
No worries, there seem to be plenty of choices at present for these!
- x 1751
Re: LHM PUMP QUEREY
Before replacing the pump (the 6+2 is very reliable), have you checked the cleanliness of the LHM fluid and the reservoir filters? Might also be worth running your system on Hydraurincage for 3000 miles.
DublinChris
Re: LHM PUMP QUEREY
Thanks white exec - yes all done including having recently changed the reservoir. Car has 213,000 miles on original pump and I have been told the issue is down to "old age" - bit like me
- x 2005
Re: LHM PUMP QUEREY
I had Pleiades rebuild mine, great job and great service. They keep some on the shelf as exchange units.
lexi
- x 134
Re: LHM PUMP QUEREY
Keep your eye on Ebay. Pumps crop up at cheaper than £300. You can buy a C5 for that!
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
DublinChris
Re: LHM PUMP QUEREY
That sounds good probably going to be a silly question but how do I contact Pleiades?Stickyfinger wrote:I had Pleiades rebuild mine, great job and great service. They keep some on the shelf as exchange units.
DublinChris
Re: LHM PUMP QUEREY
My thoughts entirelylexi wrote:Keep your eye on Ebay. Pumps crop up at cheaper than £300. You can buy a C5 for that!
- x 2005
Re: LHM PUMP QUEREY
DublinChris
Re: LHM PUMP QUEREY
Nice one have checked it out and will contact them on MondayStickyfinger wrote:https://www.facebook.com/Pleiades-Car-S ... 294714268/
aerodynamica
- x 215
Re: LHM PUMP QUEREY
Also! check the drive belt tightness - slippage here can cause it to be terrible at building pressure.
Graeme M
