Xantia rear bump stop interchangeable with C5?
c.morewood
x 55
Unread post by c.morewood »
I need to renew my rear bump stops as they are perished and will soon disintegrate. I've found some online for £40 but there are numerous pairs on fleabay for £10.
http://www.ebay.co.uk/itm/2X-Rear-Suspe ... 2322821897
Are Xantia and C5 interchangeable?
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
x 1746
Re: Xantia rear buimp stop interchangeable with C5?
Quick search on Service.Citroen shows they are not the the same, for C5-II and Xan-II.
When I replaced these on our XM, I found them cheap enough from Citroen.
c.morewood
x 55
Is £37 a pair for a bit of foam and plastic cheap? I need 3 pairs!! nearly £120 including delivery!! Why are the C5 ones only £10 a pair? I was hoping to find the foam inserts as thats the part that wears, and be able to reuse the plastic tops.
'94 Fiat TipoTd 40K
x 1955
Unread post by Paul-R »
If it's any help when I fitted some spring assisters to Xsara Estate I had to change one of the bumpstops.
There are two types of bumpstop fitted to the Xsara, a smaller harder black type and, the type I had, a larger, softer orange one. I found a replacement one on a Xsara Picasso so maybe if you look on Xsaras and Picassos you may find something the same.
x 1746
Think that the large orange foam type is to halt upward wheel movement; smaller one is to stop rebound/wheel drop.
I had to use modified (cheap Citroen) foam stops, reduced in height by half, on the XM, inside the cross-tube, as OE parts NFP. Loads of Citroen foam stops starting with the same four part number digits.
x 1955
white exec wrote:Think that the large orange foam type is to halt upward wheel movement; smaller one is to stop rebound/wheel drop.
Maybe but I wasn't looking for rebound stops. There are definitely two different types of bumpstop fitted to the Xsara as most that I came across were the smaller black ones.
