Steering rack vertical play. Worn bushings?
Axa
Unread post by Axa »
Is there anyone that have had problems with play in the ends of the steering rack?
I managed to wear out one tyre very fast due to this problem. I managed do remove most of the play by tightening the 18mm plastic internal hex plug that compress the bushing that is pressing a plastic slide bearing that keeps the rack pressed against the pinion.
Now how've close to 2 years after the steering are starting to feel a tiny bit rough and noisy. I have looked for rack end bush to replace them. But I can only find for C2 and C3.
http://www.ebay.com/itm/282053231986
I would suspect Peugeot use the same rack in some models as Citroën C5? But can't find any on ebay.
I would really like to solve this issue before I have to replace the rack!
Skickat från min SM-G900F via Tapatalk
2006 C5 1.6 HDi ( vin: VF7**************[VIN obfuscated, can be read by forum staff] )
2008 Grand Espace 2.0Dci Auto
