I'm about to upgrade the Audio system in my new ZX to something abit more serious. The amp that I have pulls ALOT of current and Im worried about draining the battery with the audio running, as I may forget to have the engine running, I'm going to be fitting a second battery but would like to upgrade the alternator to something abit more meaty. Would the Xantia or BX TD alternator bolt on?, I say these as (in theroy) they should provide more power because A) there TD's, B) they have to porvide more grunt to run the spazzy suspension.
I'm looking for something that will bolt directly on.
R
Alternators
NiSk
Alternators for diesels have smaller pulleys, since diesels don't rev as highly as petrols. So if you're going to fit an alternator from a diesel, either fit the petrol engined size pulley, or be aware of the fact and don't rev its tiny little nuts off! Try looking for an alternator off a V6 - I know that the XM V6 and diesels share the same alternator (but with different pulleys) - either 90 ampere or 120 ampere (both of which would melt your wiring). I guess the Xantia V6 has a similar unit.
//NiSk
//NiSk
rossnunn
rossnunn
Jon
I'm sure that there were 80/90/120 amp alternators fitted to the Xan 1.9TD + air. They would fit a ZX given suitable belts I'm sure.
Someone remind me tomorrow and I'll look into this.
PS BX TD no good, 5 groove pulley, ZX TD uses 6 groove, need to check ZX & Xantia with aircon and 6 groove pullys to get the highest amperage alternators.
David W
NiSk
Russell
oilyspanner
The oleo or "spazzy" suspension is mechanically powered, i would imagine any of the alternators without a fan between the pulley and the body will fit, If things are that bad re the power needs of your monster stereo why not get a small battery in a plastic box, pop it in the boot and charge it using a caravanners split charge relay, cheaply available from outdoor shops
Stewart
Stewart
