wipers gone?
mikal
wipers gone?
Unread post by mikal »
Today, spot of light rain, turned wipers on.....right one went up then just flicked back n forth a few inches, left one stayed still?
Any ideas why, fix??
Mike
08 X7 exclusive..(if that makes a diff)
elma
x 284
Re: wipers gone?
Unread post by elma »
Are they loose? Give them a wiggle by hand and check how attached they are at the base.
x 6945
Re: wipers gone?
OK - Common problem on the X7. The usual culprit is the contacts on the wiper ECUs. See my post on it HERE.
The Driver's ECU controls the passenger ECU - but to be sure which one is faulty you will need to have it checked with a Lexia - it may not be the one that seems to be faulty! I had mine done £250.
x 1996
Re: wipers gone?
Unread post by Stickyfinger »
Was there not a recall on this ??
x 6945
Re: wipers gone?
Stickyfinger wrote:Was there not a recall on this ??
Yes, recall number 19 on my table on the Wiki:
FCF Wiki
mikal
Re: wipers gone?
Yeh but.....my car is a 2008! and vin 54003777, that's for a yr later not mine? Or ....?
mikal
Re: wipers gone?
GiveMeABreak wrote:OK - Common problem on the X7. The usual culprit is the contacts on the wiper ECUs. See my post on it HERE.
Cheers Marc.
Guess I'll have to give the nice guy who sorted out my tyre press problem a call again and see wassup. I am reasonably handy mechanicly wise so can I replace the duff motor. You said you had it done? Dealer or????
x 6945
Re: wipers gone?
Yes, under extended warranty - if considering doing it yourself, you'll need to ascertain which one it is - then you'll need one of those tools to lift off the wiper armature - as these can be bu**ers to get off. If you want to tackle it yourself, let me know if you need the diagrams - just PM me with an email address - I have them here from the last couple of members who attacked the job!
mikal
Re: wipers gone?
Cheers Marc, pm gone. I will be sending the guy in north Cornwall with a lexia a message for help. Guess we just connect it up and troll to the wipers and see if a fault appears? then see which one....then try and remove/replace I guess.
Mike
mikal
Re: wipers gone?
Had to go to Plymouth for a visit, windscreen filthy, little voice said, go on try the wipers, another said, theyre f*cked you idiot, they don't fix themselves....but the first little voice won. So I flicked the arm down for a quick wipe and...........buggers worked! Back n forth, to and fro. Dayum. So on the 1/2 hr drive home was going thru what to write, started to spit, got a bit heavier and automatically put the wipers on cause they fixed themselves didn't they. One wipe, 2 wipes then...........left down, right wobbling vertically. Double and triple bugger. So obviously theres summit wrong!
x 6945
Re: wipers gone?
This is what happens Mikal - mine started doing robotic break dancing one minute, then the right one stayed up giving a finger to oncoming traffic, which is where it stayed for a while - then whilst it was waiting to go into the dealer, it miraculously decided to go back to rest position - but once it starts doing this it's only a matter of time - I wouldn't chance it in the rain as you never know what will happen. It's a sure sign one of the ECUs is bu**ered and needs replacing.
mikal
Re: wipers gone?
French cars, bit like Italian ones, such character.grrrrrrrrrrr. Now those tools I need, how do I get em?
Mike
x 6945
Re: wipers gone?
You can get generic wiper arm removal tools - but IIRC, the chap in the other post had some problems and had to improvise a bit. To be hones, I had my windscreen replaced as it was getting really pitted and that needed the wipers removing - but didn't need the tool - they came off reasonably well if you don't bend them and try to pull evenly. They do ger a load of gubbins on the spindle - so maybe a bit penetrating oil left overnight might help.
mikal
Re: wipers gone?
well I've put it off for a while and now its raining I really have to get a move on and do them. My local froggy dealer, Peugot, have said 284 squid per motor and 50 an 1/2hr labour AND a charge for the diagnostics.....but to do it myself, which I am not sure I could, would be to get a lexia test done, then find out which one is ferked and then try removing it and replace with a second hand one which will cost maybe 100 quid???? Oh what to do
Ocellia
Re: wipers gone?
Unread post by Ocellia »
It's called 'progress'? Once you had wipers, with a motor plus fuse.
Now....super-duper!!, you have separate computers, duff motors........
A friend had a P 607 SCRAPPED because they couldn't fix the wipers computer!
