2.2 dci g9t/g9u engine query?
Ian27
Unread post by Ian27 »
I'm a newbie on here and hope someone can answer my question... I have a master van with a 2.2dci g9t engine that's blown and a couple of Laguna 2.2 with what looks like the same engine...can I use one of these engines to put in my van or is there some major difference I can't see? Hope someone can help as I really want my van back on the road but 2nd hand engines cost so much...
Ian27
Re: 2.2 dci g9t/g9u engine query?
Nobody?????
daviemck2006
x 485
Unread post by daviemck2006 »
You need to give it some time to get an answer mate. We're not all glued to our screens! Your not getting ignored!
Sent from my SM-G361F using Tapatalk
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Ian27
Sorry just been a bit impatient
x 3296
Well, while I cannot help with your query, I can welcome you to the forum. :welc:
Give it time, somebody who is Renault knowledgeable will turn up and give you some information. It is just that the weather is better than normal for this time of year, so everybody is out enjoying it!
elma
x 284
Unread post by elma »
In the mean time theres a few checks that could point you in the right direction. Are the engine codes exactly the same? Is the stated power and torque the same? Do they look the same (like has one got a different shape manifold). Do they take the same amount of oil for a service?
I don't know the answer, but if I was working it out I'd look at these things as well as the engine mounts on both. I daresay they are interchangeable but you will need to swap a fair few bits over, don't take my word for it though as I'm guessing.
Ian27
Hell Razor5543 wrote:Well, while I cannot help with your query, I can welcome you to the forum. :welc:
Thanks for the welcome
Ian27
elma wrote:In the mean time theres a few checks that could point you in the right direction. Are the engine codes exactly the same? Is the stated power and torque the same? Do they look the same (like has one got a different shape manifold). Do they take the same amount of oil for a service?
Well I'm no expert by any means and won't actually be performing the transplants so to me they kind of look the same...
Ian27
Bump
