ABS Sensor Part No Confirmation?
XantiaExclusiveHDI
Unread post by XantiaExclusiveHDI »
Hi all!
Can anyone clarify if Citroen part: 96113241 is the same as part: 454573
They appear visually identical.
Thanks!
Currently:
2000 Xantia HDI 110 Exclusive Saloon (73k)
Previously:
BX 19 TZD Turbo
chinkostu
x 30
Re: ABS Sensor Part No Confirmation?
Unread post by chinkostu »
96 113 241
WHEEL ABR SENSOR
AV
- UNTIL RPO 06443
4545 73
WHEEL ABR SENSOR
AV
the part you have is for an earlier mk1 unfortunately, 454573 is for all S2 xants. is the sensor end the same?
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto :oops:
1996 306 1.8 XN Auto :?
1996 Fiesta 1.3 #-o
x 1484
Unread post by xantia_v6 »
They are not quite identical, and it is not a good idea to interchange them
wurlycorner
x 271
Unread post by wurlycorner »
I've never quite understood what the difference is meant to be here. Can someone elaborate?
When I changed a rear sensor on mine (an s1) I went for a later sensor because they were half the price. The original was metal bodied, the replacement was plastic bodied. In theory metal is more durable but in practise it got stuck solid in the arm and was a total s**t to remove.
I expect the plastic one will also get stuck solid, but at least bit should be easier to smash up come the day it needs to be changed!
The car hasn't been used in anger on the road yet, but as far as I am aware, it works ok. (Another sensor has since carped it though, of course :roll: )
Iain
CX DTR T2 Safari (silver)
chinkostu
x 30
The sensor distances are different on the early ones, i think they changed how they mount them so the newer ones have a longer body and will foul the ring on an earlier car. likewise a later sensor won't sit close enough. I'm not 100% but I think the rears are pretty much identical despite the different part numbers, it'll come down to someone having all of them to hand to check!
The other thing is would they go to the effort of making newer ones if they all interchanged!
edit: wurly Rear ones are the same on s1 and s2 after RPO 07632, so with yours being a 96 you might be just on the cusp of that. As far as price goes I managed to track some down made by Cambiare for about £20 each for the fronts
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
XantiaExclusiveHDI
OK Thanks!
I'll opt for the later part :)
Currently:
Previously:
BX 19 TZD Turbo
XantiaExclusiveHDI
Can anyone recommend a decent quality manufacturer for these - or know who manufactured the original sensors? Thanks!
Currently:
Previously:
BX 19 TZD Turbo
chinkostu
x 30
Mine were Cambiare, seemed quality. Not sure what you'd get from the likes of ebay unbranded though.
Part number is VE701103 for the Cambiare ones, less than £20 on ebay
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
XantiaExclusiveHDI
Thanks!
Cambiare just confirmed the part number for my car is VE701227 - available for around £20 online :)
Currently:
Previously:
BX 19 TZD Turbo
chinkostu
x 30
XantiaExclusiveHDI wrote:Thanks!
Good good! Mine work a treat :-D
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto :oops:
1996 Fiesta 1.3 #-o
