Total Quartz Oil, any lower cost suppliers?
reffro
I'm looking to see if anywhere supplies Total Quartz engine oils at lower/cheap prices, rather than buying it from a filling station. I'm after the Quartz 9000 5w/40 diesel oil in particular.
Jon
Um, ever heard of GSF car parts?
Quartz 9000 is the fully synthetic if thats what you want.
Part number N98002G £17.50 & VAT. This oil is approved by Citroen for Petrol and the latest DW8 and HDI diesel engines.
Its not on the Webshop as we did not have a Carrier that would take it. That situation has now changed as we have Target on board who will deliver oil/LHM. I will add oils and fluids back into the Shop.
paranoid
rg
reffro
It is the 9000 I was looking for, as I am now running a C3 1.4 HDi, and that is one of the two recommended oils. I asked the question because it wasn't in the webshop....
Anyway now we all know you can deliver oils once more, Jon is there any difference between the 9000 oils? The Citroen handbook quotes two differing types, petrol and diesel, just wondering if there is a ny significant difference apart from the packaging.
Jon
Yes, I looked into this and even phoned our Total Rep as my Berlingo handbook said to use "Quartz 9000 synthetic diesel oil". I wanted to order some for my own car as we did not stock it at GSF.
The Total bloke checked it out and said that they only did one Q9000 and that did petrols and diesels. He then reeled off the various specs which confirmed it was OK for diesels.
See here to confirm this: http://www.total-lubricants.co.yu/pdf/CitroenTotal.pdf
bernie
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Jon</i>
Jon
According to the above site they do 2 9000.
A 5/40w and a 5/30w[?][?][?][?]
Jon
philhoward
Do Parcel Force know tey've just delivered me 5 lires of LHM and 5 lires of Hydraflush, then???
Jon
reffro
paranoid
Jon
If its 5/40W Q9000 then its fine.
Paranoid, the 1.9Td runs just fine on Quartz 5000D oil, Q7000 semi synthetic for a treat. Giving it Q9000 fully synthetic is almost overkill. HDI's and the like use that oil.
They also use the "long life" oil filter 1109T1 in order to get these longer service intervals in conjunction with semi or fully synthetic oil.
JoeS
