The Lexia or not
renagade
x 10
The Lexia or not
Unread post by renagade »
Hi Guy's
Well today I opened my box with the Lexia inside and found two unknown CD's with no instructions on and a lot of cables. Well to cut a long story short I am completely bewildered by it all and have decided to send it all back.
I am no computer whizkid ( 67 years old ) and so for me no Lexia [-X [-X
I am still hoping the Guy in Rotherham will get in touch has he has the Lexia up and running and would like my DRL's turning on.
Thanks for reading my topic
There are so many roads to travel but so little time, (Paul Cofield )
x 6963
Re: The Lexia or not
renagade wrote:Hi Guy's
Although I did offer to help install it for you, I think if it's only the odd thing like activating DRLs, then maybe it is better to find somebody local willing to do this for you Renegade. It can be a bit daunting, becuase unfortunately it's not like the Diagbox versions we have to use are 'fully packaged, off the shelf' consumer software that you just click and install - one of the compromises we have to make I'm afraid. I'm sure you'll have your DRLs up and running soon. :)
x 1240
Unread post by Peter.N. »
I successfully installed mine using a video on youtube, you don't want the short ones that go at the speed of lightning but there is one that lasts about 25 minutes and explains step by step, I struggled a bit but managed it and I'm 77. :-D
renagade
x 10
Hey Peter.N
You have given me the confidence to go open the box and have a go. I am running window 7 32bit i suppose that will be ok??????
renagade
x 10
Hi it's me again,after 1 hour i think I have all in and working what I have to do now is go outside to my car and plug the Lexi in and see what happens. Good hey.
Paul
x 1240
Well done Paul, we need people to explain things carefully :wink: My laptop uses XP and it works fine on there, except on the C5 but that's scrap now so it doesn't matter.
renagade
x 10
Hi Peter.N
what was wrong with your C5, my car is the 2009 c5 I hope it would work on that. I see you have gone over to Peugeot's now did you get fed up with the Citroen's??????
x 1240
Not really although I prefer the handling of the 406, its just that four days before we were going on holiday it emptied the entire contents of the cooling system through the exhaust, looked like a '50s smog, could be the head gasket but I think its more likely that the head is cracked, Its now parked at the top of the field with my original 406 (parts dept) and four XMs and I bought another 406, I find them more reliable and easier to work on than the C5s
The hydropnumatic Citroens have gone steadily down hill since the days of the CX.
