flashing lights
froggy
(Donor 2026)
x 4
flashing lights
Unread post by froggy »
Hi, my S2 Xantia, the Airbag light is flashing on the dashboard and the seat belt light stays on !while we are belted. any help greatfully received. many thanks in advance Terry.
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
x 2008
Re: flashing lights
Unread post by Stickyfinger »
Check, disconnect, use "contact cleaner" and reassemble the under seat connections.
NOTE: DISCONNECT the batter for 20mins PRIOR to working on the wires (Air-Bag safety)
ekjdm14
x 281
Re: flashing lights
Unread post by ekjdm14 »
What he said ^^^ :)
The usual cause is movement/crap festering in the connectors under the front seats (possibly exacerbated if you have more than one driver with significantly different seating positions). When these connectors lose integrity, the airbag ECU disarms to prevent any false triggering.
Make sure you do leave the battery off for a good 20-30min before getting stuck in, an airbag to the back of the head may hurt considerably.
'95 Xantia LX 1.9D-auto, Black, 123k
'96 ZX SX 1.9TD, White, 90k
'87 Nissan Sunny 1.3L, 63k
'12 Mini freebie project
KennyW
x 165
Re: flashing lights
Unread post by KennyW »
allo allo, flashing lights !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
C3 1.4 petrol (SWMBO)
