I helped my brother buy a 1.9 Berlingo van, Unfortunatly i missed that there is a lot of black oil in the water
Citroen Berlingo Headgasket or oil cooler fault ?
imperial21
Hi
! The engine runs and drives well, doesnt use water or over heat. I remmeber that its not unknown on the hdi engine the oil cooler leaks, could it be doing it in the berlingo its a 1.9 ( like xud) engine
1999 Xantia exclusive 110BHP !! Now RIP !!
2002 C5 estate 110 hdi, Happily sold on !!!
Bick
- x 43
Re: Citroen Berlingo Headgasket or oil cooler fault ?
Yes it stands a very good chance as its a common problem
imperial21
I have just checked with my brother,The oil is the normal colour in the engine and about half down on the dip stick.
ekjdm14
- x 261
Sounds likely to be just the oil cooler although HG failure is not unknown, I'd definitely check the oil cooler option first though. Quite simple to bypass the cooler by joining the 2 coolant pipes together and you'll want to give the cooling system a good flush through with detergent (Ive used strong washing up liquid solution and washing machine capsules before now to good effect) to stop oil rotting the hoses.
Once the coolant bypass is complete and the system clean, you'll be able to tell if it's the cooler over time if oil does/does not start to accumulate in the header tank again (a small amount is possible from residual crap). More telling will be if/when the coolant stubs on the cooler start dripping oil.
Good luck & I hope it does only turn out to be the cooler. quite likely as mentioned
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
- x 1240
Head gaskets usually last about 150k miles on the XUD engine so if you are nowhere near that it should be OK.
- x 1746
Don't muck about with washing up liquid or detergent, even the bio variety.
Get hold of a couple of cans of this:
Liqui-Moly Radiator Cleaner, 300ml, art.no./part.no. 2506.
Available anywhere that stocks Liqui-Moly products, like a good motor factor.
Cleans oil etc from the complete cooling system, and does not damage hoses, seals, etc.
Extremely effective. Just follow the instructions.
Have used it on our 2.5 XM when the oil cooler ruptured, and twice! Now fitted with a non-OE item.
ekjdm14
- x 261
Can I ask why this is please, because of potential damage or just personal preference? I've never had any issue using that method previously, and indeed it's also suggested in Car Mechanics magazine occasionally. Is there something in these detergents that damages cooling system components over the course of a couple of hours? Obviously I've always flushed the whole system again with pure water after using them, before refilling with coolant. The longest it's ever stayed in was washing up liquid for about 3/4 of an hour (I ran the engine up to temperature with the mixture before draining, allowing to fully cool and water flushing).white exec wrote:Don't muck about with washing up liquid or detergent, even the bio variety.
Interested to know your thoughts on this.
- x 1746
No, I'm sure that detergent won't actually do the cooling system any harm, it's just that I've never found it particularly effective, compared to the L-M solution. There's also the issue of washing-up liquid etc foaming, which isn't helpful.
Automatic clothes-washing liquid (biological) would be preferable to WUL, as it is non-foaming, and doesn't contain salt, which could damage some components.
You're right to finish off with a couple of water flushes. The final one should be done with deionised/distilled water, to prevent sedimentation/calcification.
ekjdm14
- x 261
That's food for thought if we ever find ourselves dealing with oil in a cooling system again, not quite as cheap as a couple of washer capsules but if it's more effective then that's got to be good for the longevity of the cooling system components after oil contamination.
I wouldn't have expected too much of an issue with sediment/limescale provided the actual coolant that goes in is mixed using distilled water. Then again, we do have fairly soft water here anyway so we're lucky in that respect (it's utterly crap for quenching thirst with though!)
- x 1938
It used to be the case (and may still be) that cheaper washing up liquids used common salt as a thickener. This would certainly have a very bad effect on any aluminium or its alloys.
