Citroen c5 2.0 hdi. Depollution system faulty
Mr gee
- New User
Hi. I have just replaced the clutch and flywheel on my c5 now car has e m light on and depollution system faulty. Displayed on dash. Does anyone on hear have any suggestions Or a pp2000. To diagnose I live in Chester le street County Durham. Any help would be great thanks
jimmymarsbar
- x 13
Re: Citroen c5 2.0 hdi. Depollution system faulty
Have you checked for air leaks around the filter box? Make sure everything is well connected - pipes, box, sensors etc.
Sometimes if the BSI sleep procedure isn't followed (ie. the BSI is left to rest for a few minutes before disconnecting sensors or the battery), the disconnection will register as a fault. This often happens - I'm guilty of doing it myself (which is naughty, I should know better....). It shouldn't cause you any major issues, and should go away of it's own accord.
I'd recommend getting the Lexia diagnostics done just in case - I'd happily offer to help, but Co. Durham is a little too far for me. York is pretty much my "area boundary"
- x 1056
Does it still drive as it should ?
