radio plays but beeps
john
ive swapped the original radio from 1 xsara picasso to another xsara picasso, it plays fine but it beeps every 3 seconds or so, any ideas whats up?
Citroen Xsara Picasso
Subaru Impreza WRX
Nissan Primastar
Subaru Impreza WRX
Nissan Primastar
- x 3296
Re: radio plays but beeps
That is normal, it is a security thing. Basically because the current VIN does not match the on in the radio memory it is having a hissy fit. The way to resolve this is to hook up a Lexia system and then let the radio know it is OK for it to be in the new vehicle (I have done this, but I cannot recall where I was in the menu system).
john
thanks, im having problems with lexia, if i change over the ecus will that fix it?
Subaru Impreza WRX
Nissan Primastar
Subaru Impreza WRX
Nissan Primastar
- x 3296
I would NOT swap the ECUs, as they are also linked into the bus system, so may well introduce a massive can of worms into the mix. Until you get the Lexia resolved I would put up with the beeping, or look for a forum member nearby who has a Lexia and is willing to help. Here is the link to Lexia owners willing to help;
http://www.frenchcarforum.co.uk/forum/v ... 19&t=29178
- x 6945
Using a Lexia you need to run the Global Test, then select the audio unit's ECU. From within this you will be able to change the VIN number of the unit to the VIN of the current vehicle. Furthermore, depending on options and features, you need to be careful as this is also where several other options are configured relating to the car. If you post up your VIN of the car it is going in I can see what options need to be configured.
djoptix
"put up with the beep", lol. It's INCREDIBLY loud.
Clogzz
- x 40
Had that on the C5, the radio thought it was stolen.
Fixed by disconnecting the battery for a while.
Story in link below:
http://www.frenchcarforum.co.uk/forum/v ... =3&t=29864
Maschenazi
Sorry to revive an old post, but I just bought an old Citroen DS3 2011 and I have this beeping radio problem.
Is there anyone around Shropshire UK that has the tools to reprogramming the correct VIN number for my radio?
If anyone would be willing to help would be great.
PaulC5
- x 696
Have a look at this topic to see if there is anyone near you viewtopic.php?t=56452
