The forum has been down for a couple of hours due to a database cache file corruption.
I don't know what caused it, and I have only taken the minimal steps to rebuild the cache at this time.
If the problem recurs, I will need to do a more complete cleaning of the database itself, but would rather not do that today.
Forum outage 05/07/2016
- x 1481
- x 8440
Re: Forum outage 05/07/2015
Mike, a big thanks for all your hard work on this today, excellent work..
I guess I was very lucky when a similar problem happened yesterday afternoon and I was able to get away with just restarting the daemon!
- x 1481
I took the forum down again for some more maintenance. I have now 'cleaned' the database data files.
Lets see if it behaves itself.
- x 6950
Aahh back up - ignore email Jim - just noted the Thread Title says 5/7/2015 Mikexantia_v6 wrote:The forum has been down for a couple of hours due to a database cache file corruption.
- x 1481
Re: Forum outage 05/07/2016
I have not restored the wiki yet, as I have some other maintenance to do on that tomorrow (or Thursday).
- x 3298
Erm, I lost access to the forum for about an hour just now.
- x 6950
Wasn't being picky Mike re the 2015 in the thread - just went there to see if there were any issues and initially thought it was an older post until I saw Jim's post dated 5/7/16!xantia_v6 wrote:I have not restored the wiki yet, as I have some other maintenance to do on that tomorrow (or Thursday).
- x 1481
The server was still having issues this morning, but I think I found a problem relating to a (semi-) automatic software upgrade of the database service that happened last week. I have reverted to the old version of that package, and crossed my fingers.
- x 8440
Thanks Mike, excellent
Mine are too, plus everything else!xantia_v6 wrote:and crossed my fingers.
I don't know if this helps but it's what came up this morning when I tried to log in.
General Error
SQL ERROR [ mysqli ]
Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (111) [2002]
An sql error occurred while fetching this page. Please contact an administrator if this problem persists.
General Error
- x 1481
Yes, that was the symptom of the database service randomly crashing and restarting itself.
The version that was installed by the software updater last week was definitely wrong, so I hope that it will now be stable again.
- x 3298
Obviously that database was a final product from the Rover factories, if it could crash by itself. I had that error a few times as well. If you have a Citroen version installed do make sure to leave one small problem in it, otherwise it will get confused with being fully functional and crash anyway.
- x 8440
Hell Razor5543 wrote:Obviously that database was a final product from the Rover factories, if it could crash by itself. I had that error a few times as well. If you have a Citroen version installed do make sure to leave one small problem in it, otherwise it will get confused with being fully functional and crash anyway.
MySQL is definitey a Citroen database as when it works it is brilliant but when it doesn't it can be a bit or a *********
Luckily the not working time is often very, very small. That differentiates it from a Rover... That's Microsoft SQL Server
I know only too well - it's how I earn my money....
