While going over my other half's 2002 C5 2.2HDI auto yesterday I noticed that, although the TPS progression is nice and linear, the reading doesn't go above about 88% at full throttle.
After a bit of rummaging about and following the cable, I tracked down the TPS under the fuse box and it seems to have the apparently common problem of the cable having stretched so thats going to be an easy fix
BUT I also noticed in Lexia that there are 2 'hard spot' sensor readings for the TPS as well, one normally-open and one normally-closed. One of these always says 'pressed' and the other 'released' regardless of the position of the pedal - even if I take up the spare play in the cable.
I assume these are supposed to be the ECUs simulation of the 'hard spot' on cars with auto boxes and kickdown cables - so I'd have expected the 'pressed' and 'released' to swap over at full throttle but they don't
Does anyone happen to know what these to sensor readings *should* do - or is there a 'hard spot' built into the TPS (ie beyond the normal 100% open) and I just didn't pull the cable hard enough to get past it? I am guessing that these readings get fed as an input to the 4HP20 auto box for kickdown?
Thanks,
Martin
