Sphere swap
kiwifrog
Sphere swap
I came across a 95 xantia wrecking on our local auction site and i wouldn't mind getting the spheres, my Xantia is a 93 sinker so will these spheres fit ? I would get them re gassed to 93 specs if need be......
- x 1484
Re: Sphere swap
As long as the donor car has standard suspension, not hydractive, the spheres will be compatible. Hydractive cars would normally be badged VSX in NZ.
kiwifrog
Re: Sphere swap
Bugger, its a 2.0 8v auto vsx.
- x 1240
Re: Sphere swap
They will be a bit hard
Mandrake
- x 697
Re: Sphere swap
VSX spheres won't be suitable for your SX as the damper valves are wrong.
Also depending on how old the car is and when its spheres were last replaced you could be buying duds anyway. Spheres can only be re-gassed if they have not been allowed to go too low in pressure. Depending on who you believe its recommended not to re-gas spheres that have fallen to below 1/2 their normal pressure or below 15 bars.
Also any long life spheres (which have three dimples in the sphere body around the filler cap at the top) should not be re-gassed. Some Xantia's in New Zealand were fitted with the long life spheres on the front suspension. (My VSX was)
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
1978 CX 2400
- x 1746
Re: Sphere swap
Simon,Mandrake wrote: Also any long life spheres (which have three dimples in the sphere body around the filler cap at the top) should not be re-gassed.
Why is this?
Do know that saucer spheres should not be, but old shape?
Mandrake
- x 697
Re: Sphere swap
Already been discussed in great detail in another thread recently Chris.
But in short, the long life type spheres only lose significant pressure after one of the diaphragm layers has ruptured. Thus a low pressure warranting re-gassing is a fairly sure sign that the diaphragm is already failing. At that point any attempt to re-gas is not going to give any long term satisfactory result.
Simon
1978 CX 2400
1978 CX 2400
- x 1746
Re: Sphere swap
Thanks for the quick confirmation. I missed the earlier post about this. Have a couple of these on XM front.
kiwifrog
Re: Sphere swap
Do you know of anyone in ChCh that can test my spheres presure ?Mandrake wrote:VSX spheres won't be suitable for your SX as the damper valves are wrong.
