C5 Facelift HDI 2.0 cat temperature sensor
dnsey
x 19
Unread post by dnsey »
Does anyone know where the connector for this is?
I'm getting an intermittent open-circuit fault, which is hopefully just a dirty connector. Having traced the cable beneath the heat shield, I see it emerge behind the brake servo, but for the life of me can't find it again from above. I cant't believe that it just joins the ECU loom, as that would make replacement a major operation; there must be a connector somewhere, but where?
Thanks.
