steering wheel not horizontal
Nikolaymk
I've just noticed that when cruising on the m-way my 4 spoke steering wheel is not perfectly horizontal when the car goes straight ahead (as it used to be) but is tilted to the left a bit. Also when I let go, the car goes slightly to the right. The wheels have been balanced and alighned a week ago. What else can cause this?
AndersDK
jeremy
edd001
Dave Burns
Uneven tyre pressures and odd front tyres can have the same effect, if its gone like this for no apparent reason then there is something going pear shape for sure.
Any good tyre place will have the latest four wheel allignment equipment and hopefully a good bloke to meddle about with it, thats the sort of place you want to go to, they will set the steering wheel on centre and adjust the wheels to the correct angle.
Dave
Dave
Nikolaymk
Yes, this is exactly what they did. I'm not sure if the steering wheel was tilted before the alighnment as I only noticed it yesterday. In the garage they secured the wheel to the seat in horizontal position and only then did the laser stuff with the tyres. I guess since the work is guaranteed I'll go back and ask them to check it.
Will uneven front tyre wear cause this AFTER the alighnment? My fronts are a little more worn on the outside, that's why I did the alighnment on the first place.
AndersDK
Dave Burns
Good point from Anders about changeing wheels over, but perhaps it would be better to change the fronts over only, if it is just a tyre problem the steering should pull to the other side, the rear tyres being an unknown quantity in such instances may be best left out of the equasion.
Don't alter the pressures just swap straight over, if you change any of the variables you wont know whats what with the results.
Dave
Dave
Nikolaymk
MarcusB
Yep, get the alignment rechecked. You might expect the car to veer ever so slightly to the left (in LH drive countries that is!) because of road camber, all else being sound.
Re. tyre rotation: Subject to the generally accepted wisdom that it's safer to have your better pair of tyres on the rear, I reckon it's a good idea to rotate the tyres because the wear rate is so much higher on the front than the back (for FWD vehicles) that rear tyres may well die of old age rather than wear out. Happened to me.
Opinions vary on how often this should be done, say every 12k / i.e. every other oil change?
see e.g. http://www.bridgestone.com.au/tyres/pro ... tation.asp
AndersDK
Nikolaymk
I just had the alignment rechecked. The chap that did it the first the time did it again. This time the steering wheel tilted to the right. I let him drive it around the block to see how "perfect" a job he had done. After that it took 3-4 people the best part of an hour to do the alignment properly and the wheel is now perfectly horizontal.
So be careful out there. I wrongly thought that they would put someone experienced on a job like this. But apparently it's always the rookies.
