Hi all, I was wondering if anyone has the Citroen factory or dealer service manuals for the early Mk1 Xantia. I am hoping someone might be able to scan the wiring circuit for the hydractive II layout (specifically the pin outs of the two multi plugs at the ECU and the wire colours/ markings)
I have comprehensive service manuals for all XM models including the Hydractive I and II so can glean some info from that but the wiring colour markings will no doubt be different.
Thanks in advance!
Graeme
Xantia VSX factory manual page scan request
aerodynamica
- x 215
Graeme M
aerodynamica
- x 215
Re: Xantia VSX factory manual page scan request
Right, I have found some documents on Hydractive II as a pdf of 'training modules' and the full pin out description for everything on the two connectors is there. It is simply the wiring diagram I am after now to find the colour/ markings of the hydractive II wires to and from the connectors.
Graeme M
- x 8406
I have it Graeme, I'll see if I can sort it out. FWIW, all S1 Hydractive wiring is the same....
These are for the S1 Activa but apart from the third (Activa) electrovalve, they're the same...
Circuit Diagram
Harnesses
Location Diagram
If you really, really want the early ones then I can but not until I fire up my scanner and that might be a while... Please advise
Circuit Diagram
Harnesses
Location Diagram
aerodynamica
- x 215
Thanks Jim, Citroen God status firmly displayed!
Graeme M
- x 8406
aerodynamica wrote:Thanks Jim, Citroen God status firmly displayed!
