How hard is it to put new pads on Citroen xsara Picasso ? I've not done it before but would like to try it myself, how hard a job is it from 1 to 10, 1 being easy.
It's 2005 model
Front brakes
- x 1995
Re: Front brakes
Standard stuff really, Do you have a Haynes book for the car ?
Ttwlr
Re: Front brakes
Looked for video on how to but nothing for my car
jimmymarsbar
- x 13
Re: Front brakes
3-4, depending on the state of the bolts and guide pins. On my 307, the were battered, and I ended up rounding out the head.
Also, invest in a good brake bleeding kit, as you'll need to push the piston back without causing air to get in to the system. To push the pistons back, a g-clamp is probably the cheapest device to use, or pay a bit more for a wind-back tool.
In a nutshell, it's a case of;
jack car up
wheels off
remove caliper
remove pads
check condition of disc
wind back piston (you may need more info on this)
new pads on
new guide pins
caliper back on
torque up
wheels on
lower car
torque wheels
jack car up
wheels off
remove caliper
remove pads
new pads on
new guide pins
caliper back on
torque up
wheels on
lower car
torque wheels
van ordinaire
- (Donor 2017)
- x 400
Re: Front brakes
If they wind back (will have 2 indents/registers on the face) wouldn't recommend using a G-lamp, which is fine for those that just press in.
In either event, I'd avoid backing off bleed nipple to make it easier, if at al poss - simply because I'm paranoid about shearing them.
Citroens:-
'81 2CV Club
'05 C15
'97 Xantia Exclusive estate
others:-
Jeep XJ Cherokees x 3
'96 Cadillac Eldorado
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
- x 1489
Re: Front brakes
Std brakes on the front of a Xsara Picasso, no need to wind back. If it's never had new discs, then it will probably need those as well, which complicates matters a bit. I can't remember the specifics on this car, it was a while ago, but I don't remember it being too hard. There are several different types of pads, so you will need to get the wheels off and have a look to see which is fitted. There are plenty of how-to's on youtube - but i couldn't obviously see one for Xsara Picasso. It's all pretty similar though.
Ttwlr
Re: Front brakes
Many thanks guys
Will take a look sunday
Ttwlr
Re: Front brakes
Had brakes done but discs need replacing as mentioned, been looking for some but was asked what size mine are ?
I said I have no idea, I gave them my reg so thought they would have know by that
Would these fit
BARGAIN AUTO PARTS
Specification
Part Number DSK519
Make Citroen
Model Description Xsara Picasso 2.0 HDi
Model Range Xsara Picasso [00-10]
Year 6/2000-3/2006
Centre Diameter 66.0mm
Disc Diameter 266.0mm
Disc Thickness 20.5mm
Disc Minimum Thickness 18.5mm
Mounting 4
Disc Overall Height 27.4mm
Disc Type Vented
Fitting Position Front
Product Description Apec Brake Disc
Quantity 1
Would these fit
BARGAIN AUTO PARTS
Specification
Part Number DSK519
Make Citroen
Year 6/2000-3/2006
Mounting 4
Disc Type Vented
Quantity 1
