I've got a picasso exclusive 64 plate, water drips straight on to the edge of the rear seats when it's wet after opening the rear doors. With the light grey trim, I have water stains on both sides now. Does this need attention or is it a general design fault??
Picasso, Door Seals - Have I got a dudd?
Snake Trainer
- New User
- x 6955
Re: Picasso, Door Seals - Have I got a dudd?
Have you taken it to the main dealer? Should still be under warranty. Insist on them sorting it out - show the wet carpets and tell them you don't want the floor plate rusting from the water damage. I'd take it back while you still have the cover!Snake Trainer wrote:I've got a picasso exclusive 64 plate, water drips straight on to the edge of the rear seats when it's wet after opening the rear doors. With the light grey trim, I have water stains on both sides now. Does this need attention or is it a general design fault??
Snake Trainer
- New User
The water drips on the seats from the seals when the doors are opened after rain, sorry if I didn't explain properly.
- x 6955
Ok, got you, if there's no obvious damage to the seals (pinched, kinked) I can't think what else it could be. This is the first I've heard of this issue
- x 1988
Gutter-less cars, wonderful things for drips and pouring water onto window switches at the first corner in the morning
- x 6955
I'm the snow its even more annoying - instant DIY snowman!
