Alternative refrigerant pressure sensor?
Post your Cit/Peu/Ren air conditioning queries or advice.
teuski
x 11
Unread post by teuski »
I need a new refrigernat pressure sensor for my '96 ph2 Safrane. I can't seem to find new ones, at least not for a reasonable price.
Since the AC system is pretty much the same in all cars, i suppose some other car's sensor would do the job if it fits physically.
I suppose the sensor operation and values are pretty much the same anyway.
Maybe some early Laguna/Megane sensor might fit, i don't know. All i know is that mk1 C5 sensor is different.
There is a valve that prevents the loss of refrigerant when the sensor is removed so the physical dimensions are important to open that valve.
A different kind of connector isn't a problem as long at has 3 wire and that it is actually a sensor, not just a switch.
The original sensor has following markings:
Valeo
652113F
24067766
21596 ?v
Some dimensions:
  • Opens with a 19mm key.
  • inside theres a 10mm coil finer than M10.
  • the sensor side opening is 11mm, the coil starts at 5mm depth
  • the distance from the end to the pin in the middle is 11mm, 13mm to the pin's "spokes"
  • outer diameter of the sensor side connector is 17mm
Any tips would be helpful :)
x 1429
Re: Alternative refrigerant pressure sensor?
Unread post by xantia_v6 »
Are you sure that it is a sensor not a (trinary) switch? More than one supplier lists Renault part number 7701041413 as fitting the Safrane II, there seem to be several suppliers for that part.
This one looks rather similar: http://www.ebay.co.uk/itm/AIR-PRESSURE- ... SwstxVUwOK
teuski
x 11
I'm not really sure how a trinary switch should work, but this one gets +5VDC on one pin and earth on the other. By varying the 5 volts to the 3rd pin by means of a adjustable resistor the compressor clutch engages at certain point and the engine fans start and vary their speed according to the resistor.
Anyway thanks for the tip. I decided to try my luck and order such switch. The pics of the connector aren't that clear but looks like it wouldn't be the same.
teuski
x 11
This sensor for Dacia Duster works just fine :)
