c5 just cut out and wont start again
colin machin
hi c5 2.2 diesel just cut out and wont start again . in the past its cut out when i accelerate heavily for just a second and restarted on its own .last year it would not start at all in the morning i just pressed all the wiring i could see and it started and its run for 12 months with no problems its a 2007 model thanks
C5 2007 HDI
jimmymarsbar
- x 13
Re: c5 just cut out and wont start again
Best place to start is diagnostics. If you can get it on Lexia or Diagbox, that should begin to give some indication with stored faults.
jgra1
- (Donor 2021)
- x 36
Could be worth some easy start to see.if you can get her running again
- x 6950
Given what you have said already, "..pressed all the wiring I could see.." would suggest that you may have a loose connection / plug or some dirt in one of the connectors if not a loose or broken wire wherever it was that you were poking about!
A systematic check and clean up of all your connectors with some electrical contact cleaner may be worth a shot in the first instance - put it this way - it won't make things worse than they are. Then get it on a Lexia for a global test, clear the faults, and re-test. Any faults that remain can be accepted as 'new' temporary or permanent faults and will form the basis of where to start.
