Want to get new brakes all round for my xsara Picasso 2.0 HDI
Was told I need part number as there's different types, how can I find this out please, it's a 2005 exclusive model.
Brakes part number
- x 1504
Re: Brakes part number
Post up the last 8 digits of the VIN and we can look up the brakes fitted.
Ttwlr
I'm getting all the parts for a full service and don't want to get wrong parts, can I use 10w 40 Castrol Magnatech oil ?
- x 1504
Yours has no ESP and Bosch brakes on the front:
Discs:
4249 16 (original part no)
RP 4249 83 (superseeding part no)
2 FRONT DISKS KIT, VENTILATED
DIAM 266 EP 22
Pads:
4253 42 (original part no)
RP 4254 75 (superseeding part no)
BRAKE PAD KIT FRONT
These pads are the ones with the 'ears' on.
Rear brakes are drum (only one type of shoes for rear drums)
Shoes only:
4241 L6
RP 16 100 912 80
BRAKESHOE SET
228X40
Fitted up mounting kit including adjusters:
4242 22
RP 16 100 913 80
FIRST MOUNTING BRAKES KIT
DIAM
10W 40 semi synth is what I used to use in 2.0 HDi engines
Discs:
DIAM 266 EP 22
Pads:
BRAKE PAD KIT FRONT
Shoes only:
4241 L6
RP 16 100 912 80
BRAKESHOE SET
228X40
4242 22
RP 16 100 913 80
DIAM
- x 6950
Richard - don't they also say you need the anti-rattle 2 shim set (4407 09) if using the 4254 75 pads according to the note?
Ttwlr
Many thanks for the information,
Can start looking now
- x 6950
I would order the shim set too - shouldn't be expensive, but the service docs say these are needed with these pads - the ones you will have already are probably meant to be replaced with the pads.
- x 1504
It was about 6 years ago, but I'm pretty sure I just re-used the shims when I changed the pads on mine - or didn't bother fitting them - no recollection of buying them.
Ttwlr
I've got some new rear pads that I got for my other car and never used them, they are Eicher brakes 101440329
Anyone confirm there fit mine and one site selling says yes and another saying No.
- x 6950
Your Picasso doesn't have rear pads it has drums and brake shoes, as they only fitted rear discs and pads to the models that year that had the Electronic Stability Programme (ESP) fitted, so no they won't fit! That's why Richard listed brake 'shoes' with the rest of the kit in his post.
Ttwlr
So sorry I missed that bit,
Thank you
Thank you
- x 6950
No problemo!
