What are people doing for replacement clutch cables? Original parts seem to be discontinued from Citroen and motor factor is offering a replacement to correct part number but it has automatic adjustment. My series 2 1998 1.9TD has a non automatic adjusting cable. Mine has not broken but the clutch action does not feel great even though it has a new clutch so was going to try change cable to get a smoother feel to pedal action.
Any thoughts?
clutch cables
DublinChris
clutch cables
Let the good times roll
current every day 1998 Xantia turbo diesel 1905cc series 2
Xantia97
Re: clutch cables
The local Peugeot garage here in France tried for a whole day to put a third-party self-adjusting clutch cable on Snoopy (1997 S1 Xantia) and failed - it would not work. So I managed to find a new OEM cable in the UK and that went on like a dream.
There do appear to be some OEM parts around but you have to search.
Good luck,
Juliet
Good luck,
Juliet
1997 Xantia 1.9TD LX (owned for 14 years) - Snoopy
Gone but always remembered
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
GS Pallas
GSA X1
AX - bad mistake!
ZX 1.9D
3 x Opel Manta
daviemck2006
- x 485
Re: clutch cables
Go to your local dealer, they will do a search of all dealers and it may be available somewhere and you can contact the dealer who has it and they will post it to you. Has to be worth a try.
Sent from my SM-G361F using Tapatalk
Skoda Karoq 1.6tdi 2018
Peugeot boxer 2016
In the family
C1 vtr+ 2010 daughter 2
Peugeot boxer 2016
In the family
DublinChris
Re: clutch cables
I have done all that in Ireland there are not too many options just one main dealer/importer Gowans after that it's GSF etc.daviemck2006 wrote:Go to your local dealer, they will do a search of all dealers and it may be available somewhere and you can contact the dealer who has it and they will post it to you. Has to be worth a try.
DublinChris
Re: clutch cables
Thanks Juliet good to know before doing the same thing will try eBay etc see what I can getXantia97 wrote:Hi,
Good luck,
Juliet
Re: clutch cables
Try GMF they seem to be good for this stuff, have branches all over the country, the boss has Irish connections but I don't know if he's in business over there.
http://www.gmfmotorfactors.co.uk/index. ... &Itemid=59
DublinChris
Re: clutch cables
Thanks fro the lead Gibbo 2286. I started with GMF which eventually brought me to Micksgarage. They had a non self adjusting cable so I have the longer self adjusting and the shorter non self adjusting. Believe it or not it will be next tuesday before car goes in to have cable changed so hopefully the shorter one will work!
DublinChris
Re: clutch cables
Just to update this thread. the non self adjusting clutch cable proved to be too short so the self adjusting one was fitted. It went on smoothly with no alterations needed so even though original was non self adjusting the outcome seems to have been satisfactory.
jgra1
- (Donor 2021)
- x 36
Re: clutch cables
does it feel better Chris?
john
john
- x 8423
