synergie air con/venterlation
waveyr02
Unread post by waveyr02 »
Hello All I have a year 2000 synergie hdi with digital air con the problem is it is totally uncontrollable, when you start up it comes on its own you can press the off button, sometimes it goes off others it just stay on then it will switch up and down on its own basicly all over the place. any ideas would be most welcome as its driving me mad.
ken newbold
x 4
Re: synergie air con/venterlation
Unread post by ken newbold »
Not had any problems with the 806/Synergie, but we used to get this with the BXs, it was the diode in the fan control that failed, I think these are mounted in the motor housing on the Synergie. The only other thing I can think would be the control unit itself, much eaiser to change that, so that wold be my starting place.
1998 1.9td Peugeot 806 (Red shed 2)
2004 Citroen C3 1.4HDi
2003 2.2 Pug 807, Gone and never again!
waveyr02
Thanks Ken ,bye control unit do you mean the controls themselves or is it a separate box hidden somewhere in the dashboard.
Thanks Simon.
ken newbold
x 4
The control unit next to the gear stick. Do you have one?
waveyr02
yes have one there.
ken newbold
x 4
Sorry, meant have you a spare to try?
djoptix
Unread post by djoptix »
As an aside, I honestly don't get the point of climate control. Other mod cons I approve of (cruise control, rain sensing wipers, automatic lights etc) but I don't see what's wrong with turning a dial when you want the car to get colder or hotter. I also like having a button to press to turn off the air con, but that's just me...
x 6955
You can still turn the air con off with the button - it's not one or the other. Climate control just maintains the set temperature for you, but not only that, it prevents the misting of windows when running and ensures a constant temperature in the cabin, without having to keep turning the air con on and off and the blower up and down and adjusting the hot and cold - and getting groaned at from everyone. I have mine at between 18 and 21. I've read somewhere that 21 Centigrade is the ideal remperature in the car - but of course everyone is different. :-D
x 6955
waveyr02 wrote:yes have one there.
If you need the part number for the replacement, post up your VIN :wink:
ken newbold
x 4
I bet these are almost into 4 figures for a new one
x 6955
ken newbold wrote:I bet these are almost into 4 figures for a new one
Not quite - but almost! £811.40 + VAT = £973.68! For a brand new one - if available (Part 6451 JG) that's if this is the 2 fan unit with automatic air conditioning.
ken newbold
x 4
good guess then :lol:
waveyr02
New one out of the question (more expensive than the whole car value!), think I might have to hack it about a bit maybe a on /off switch in place of the main fuse just to switch it off.
ken newbold
x 4
Yours is one of these, yes?
If you wanna borrow this, send me £35 and I'll post it to you. If it solves the problem you've bought it, if it don't you can return it and I'll send you £30 back. Hows that?
waveyr02
yes sounds good to me, will you pm me then.
Thanks Simon.
