Citroen c5 1.9 hdi 2003 Horn not Working
eddie567
Hello gang my Citroen c5 horn as suddenly stopped working its a 2003 any ideas ive checked the fuse and its not blown in pulling my hair out many thanks Eddie.
- x 6955
Re: Citroen c5 1.9 hdi 2003
I think we'll need a bit more of an explanation than that Eddie
Can you start by explaining what is / or is not working?
Do you have ignition lights?
Does the car turn over?
Do you have power to any of the electrical devices in the car - i.e. do the lights turn on?
Can you hear the fuel pump humming when try to start?
This would at least give some of us a place to start.
- x 1924
On my old 2003 C5 the electrical connector would quite often fall off the low note horn. I don't use the horn very often but if it was just a feeble "parp" that would tell me that it needed looking at. Don't know whether your spec of car has two or one horns but take a look at it/them From memory they're on the LH side of the car behind the front bumper.
BTW, the car won't be a 1.9. It'll be a 2.0 or, more rarely, a 2.2.
- x 1924
Can I also suggest that you add to the title of this thread to include "horn not working" and remove that bit from the title of the other thread.
eddie567
Hello mate everything is working fine on the car its just the horn that suddenly stopped working cheers Eddie
- x 6955
Apologies Eddie - my problem - I missed 'Horn' out from your post!eddie567 wrote:Hello mate everything is working fine on the car its just the horn that suddenly stopped working cheers Eddie
Anyway, general advice is first to check the fuse (can't remember now which one it is on an 03 - check the handbook if you have one), next give the horn a bit of a whack - sometimes this is enough to get it going again.
