xantia leaking
davoxx
x 15
xantia leaking
Unread post by davoxx »
Thought I'd ask before I started digging into it, I have a small leak that seems to be near the front passenger headlight. It seems to be trickling down onto the under tray.
Any idea what it is and is it a case that it might be a job that could have a complication?
why?
elma
x 287
Re: xantia leaking
Unread post by elma »
That may be your water pump or radiator. Hows the coolant level?
May be LHM.
Hopefully it's your screen wash.
If it's the water pump it can turn into a big deal if it isn't fixed.
Have you looked under the bonnet? Is the fluid watery or oily?
davoxx
x 15
Re: xantia leaking
it is definitely LHM, and I think the location is under the reservoir, guess I'll have to do a bit of investigation :(
why?
Mandrake
x 694
Re: xantia leaking
Unread post by Mandrake »
If its an LHM leak coming from under the reservoir, it's probably the anti-sink valve leaking as it is situated right underneath the reservoir tank.
A common problem that can often be fixed with a new o-ring - search the forum for details. If you're replacing the o-ring make sure you use the right grade of high pressure oil resistant o-ring, "standard" o-rings will fail again in short order as they can't tolerate LHM or the high pressure they work under.
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
davoxx
x 15
Re: xantia leaking
So it seems like the strut return was cracked and leaking before it snapped and made a mess, I have a temp fix in place until the replacement part is sorted.
Is this the tool I need for the clip => http://www.ebay.ie/itm/271877017714?hash=item3f4d221072
I'll check the anti-sink valve too, as I'm sure the leak appeared from the front near the headlight too.
why?
