havent been on for ages just been mega busy with other stuff. I'm having a problem with my 03 c5 estate when turning at low speeds at full lock i get this unmerciful clunk i have replaced drop links, ball joints inner and outer tie rods, passenger side driveshaft as it was caput, replaced drivers side outer cv joint, control arm bushings left and right, as you can imagine I,m at a loss there doesn't seem to be any play in the rack but im not sure how to test it. could it be a strut bearing or something else.
clunking from front when turning in driveway
darbuck
- x 289
Hi lads,
Darren
- x 1240
Re: clunking from front when turning in driveway
Sounds as thought you have done about everything. Is it a continual clonking or clicking when on full lock or only occasional?
darbuck
- x 289
how are you doing peter its just one solid clunk appears to be more noticeable on full lock to the right
Darren
c.morewood
- x 55
Hi Darren,
Assuming your C5 suspension/wishbone is similar to the Xantias. I've just replaced the front wishbones on my Xantia. I stupidly put a bit of grease on the P bit of the rearmost bush on both the wishbones to enable them to slide into position easier... with the result I get a clunk as they move about under load, no matter how tight the bolts are. I'm going to have to take them off again end remove the grease.
I'm wondering if one of your rear bolts isn't done up tight enough, resulting in the wishbone being able to move 1-2mm and create the clunk as you reach the extremity of turn? That clunk sounds deep and is, once you realise what it is, obviously a chassis noise rather than a peripheral clunk. Hope that helps.
Tesla Model 3 LR DM AWD Blue White
'00 Xant 110HdiSX Est 83K "W"
'99 Xant 110HdiSX Est 320K "V"
'98 Xant 1.9TDSX Est 150K "T"
'97 Xant 1.9TD 20k Est
'94 Fiat TipoTd 40K
'85 BMW K100RT 330K Garaged 26yrs '80 Honda CB250 twin Superdream
'94 Fiat TipoTd 40K
darbuck
- x 289
cheers ill check that out tomorrow could be, as i removed both arms to replace bushes may have loosened i think i greased mine aswell so maybe thats the problem.
Darren
- x 1240
The only other thing I can think of is the bottom ball joint.
darbuck
- x 289
i suppose its possible one of the lower ball joints have failed prematurely or was faulty to begin with ill check it out and update
Darren
darbuck
- x 289
hi lads tightened up bolts on arms got an extra 3/4 turn and voila sorted thanks for your input
Darren
- x 1240
Well done.
