Info on Nemo Particulate Filter?
vonsworld
Unread post by vonsworld »
Please could someone give me some information on the particulate filter in a Nemo Van/Multispace from 2009?
What is the type of filter? Does it just collect soot or also burn it off when you run at higher speeds?
Is there a fluid that needs to be added to keep the filter working properly?
Thanks for your advice :-)
vborovic
Locked user account
x 40
Re: Info on Nemo Particulate Filter?
Unread post by vborovic »
It might help to know which exact engine you have ...
x 6955
vonsworld wrote:Please could someone give me some information on the particulate filter in a Nemo Van/Multispace from 2009?
Post or PM your VIN and we'll be able to tell you what system it has.
vonsworld
Thanks, this is a HDi 1.4 8V, I'll send you a PM with the VIN
vonsworld
You sometimes get a small amount of smoke when you start the engine, but none afterwards. Is this normal or does it perhaps mean the filter is filling up?
x 6955
You have the 1.4 DV4TED Engine (Euro 4).
Your vehicle has an EGR system with a Catalytic Converter - you don't have an additive system on this vehicle. :)
x 1480
That doesn't sound right Marc... euro 4 will not have a DPF - that came in with E5; E6 adds the NOX SCR / adblule malarky. Don't know about the ECU monitoring the oil either - neither of my DPF equipped E5s do this; oil change is just on mileage, and no need for diag tool.
