Service parts for 305
2011dandd
x 4
Unread post by 2011dandd »
Can anyone shed any light on the part numbers I need to service my 1.8 diesel 305 I've recently bought.
Can't find much or any info on them
spider
x 77
Re: Service parts for 305
Unread post by spider »
Oil filter will be the same as all XUD's 1109N2 is the 'official' part number. Note: Do not use the 'later after 1997/1998' 1190T0 filter on these. You can but I'd not recommend it. Third party ones may all be the same, these are OK though.
Fuel filter: There's going to be a big choice here depending on what was factory fitted, although my 205 (yes I know you said 305!) had a Lucas system it had a Bosch filter assembly fitted. A pic of what you have now will help. Ebay is showing two types for instance. This is assuming that you have what the factory fitted and not a later design from another vehicle which is quite possible. :)
Air filter: The same will apply here I guess. A factor will be able to supply one.
The problem with 'manufacturer' part numbers (apart from the oil filter) is they will no longer have them in most cases.
Andy.
Oldpug
x 94
Unread post by Oldpug »
Your best bet is to give Dean Hunter your reg` number and make of pump and he will mail the stuff to you.
http://www.peugeotparts.co.uk/
