Should I use engine flush?
boristhespie
x 4
Unread post by boristhespie »
Getting my 136nhp C5 06 diesels oil and filters changed. The garage just asked me when Kbooked it in, if K would lile to have my engine flushed. I THINK IT IS forte. I just said yes, but I wondered immediately I put the phone downn if I needed this. I also seem to remeber some post saying it could do more harm than good. So should I get it done or not. Can you advise?
C'est pas possible!
x 5652
Re: Should I use engine flush?
Not likely to do any harm unless there are mountains of crap in there and if it has been serviced regularly then that is unlikely.
x 6955
Ditto above, Steve is right - Engine cleaners are designed to keep clean engines cleaner for longer. Not recommended for older engines that haven't been cleaned regularly as you'll just churn up all the crud in there and this could potentially cause you more severe problems.
x 1987
Unread post by Stickyfinger »
I do and always have, on older engines it is no different than putting in a modern oil when considering the "crud" (but what is an older engine ?).
x 6955
No problem if you have a clean old engine! If you have always used flush then it won't be an issue - but to start using it on an older engine that hasn't been flushed isn't such a good idea.
Jaf
x 42
Unread post by Jaf »
Where I worked, a long time ago, they used to buy/ sell cars as well as being a garage. They would sometimes flush the engine with paraffin. Made me wince!
So no, I wouldn't flush it.
Fred, a silver 1998 1.9TD SX Xantia.
Gwin, a white 1994 1.1 AX.
x 1751
Modern engine oils are highly detergent, and so tend to keep things very clean anyway. I've been surprised how clean sumps and head tops have looked on even a diesel after best part of 200,000 miles. Last time I saw sludge of any kind was back in the 60s amd early 70s.
Bick
x 44
Unread post by Bick »
Yep no worries
boristhespie
x 4
It jasnt had an oil change for a year. Naughty of me. Up until then it had one maybe every 7 months or so. Never been flushed as far as I know.
C'est pas possible!
x 1751
Nothing wrong with an oil-change once a year, or at recommended intervals.
elma
x 287
Unread post by elma »
I have no problem with flush but would be cautious with it. The reason I think this is I once had an apparently good engine, upon flushing it developed the symptoms of worn piston rings and did't last much longer. Now my method with a newly acquired engine is 3 oil changes 1000 miles apart then flush only if necessary and if all seems healthy. With a known healthy engine I think flush is good, it's just a case of being certain the engine isn't overly worn first.
x 6955
Agree - regular oil changes are much better, there are plenty of mechanics who warn against flushing, but your choice, as none of us here know the history or condition of your car.
Here's some general info on oil sludge and flushing from cr Bibles:
http://www.carbibles.com/engineoil_bible.html
The above article even warns against putting fuel additives in your tank - which IIRC the Citroen servicemanual also 'forbids'.
x 1987
GiveMeABreak wrote: - which IIRC the Citroen servicemanual also 'forbids'.
It also recommends (instructs) stupidly long times between oil changes, which we know results in a failed turbo in the 1.6 because the filter in the feed gets blockd
x 6955
Never any harm in more frequent oil changes and probably a good idea. Another example of real world examples - especially as you say with regard to the 1.6.
x 5652
Only had it done once, on the Accord. Certainly did no harm even if it did no good.
