OBD fault scanner which one
tonyhag
Unread post by tonyhag »
I have a Konnwei KW808 OBDII/EOBD scanner which I bought last year to use on my fiat ulysee w reg and even though a few functions did not work it did what i needed it to do, now I have A Citroen C8 2.0 ltr 136 BHP which is a 96 plate and it seems according to the Ebay seller I bought this scanner off that it does not work with Diesel vehicles so anyone recommend an OBD scanner that I can use with the C8 diesel vehicle.
x 3298
Re: OBD fault scanner which one
The cars from Peugeot and Citroen do not always communicate in a standard format, so what you need to do is to get a decent Lexia clone. They are not cheap (compared to generic code readers), but they can do a whole lot more.
Oh, welcome to the Forum, by the way. :welc:
x 2008
Unread post by Stickyfinger »
Hell Razor5543 wrote:They are not cheap (compared to generic code readers), but they can do a whole lot more.
And nor are "Reads" at the dealers
tonyhag
Yer already seen the Lexia scanners and probably will get one as these things always pay for themselves in the long run.
x 2008
long run ??......quite a short run with main dealers normal charge between £60-80 a pop
