c5 2.0 hdi Strange Immobiliser / Battery Drain Fault
grendal10
New User
Unread post by grendal10 »
im having a few problems with my c5 2.0 hdi 2002, first problem was the battery was draining completely if not used for a day to 2 days, which turned out to be the rear interior light, if its turned off the bulb still has a small glow . i then found out if the bulb is removed or the interior light is unplugged the car wont start and comes up with immobiliser fault, if the bulb is plugged back in and ignition turned off and back on the fault goes and the car starts fine. just wondered if anybody had any ideas?
x 1746
Re: c5 2.0 hdi Strange Immobiliser / Battery Drain Fault
That sounds like a failure of supply to some part of the car concerened with starting. The interior light is temporarily providing a supply, instead of the IGN switch - which is why the battery goes flat: akin to leaving the IGN switched on. Can't help further without the circuit diagrams.
x 6950
Have you 'added' anything to the car such as any electrical items or changed the Stereo at all - or basically spliced / cut / added / removed any wiring?
