AX 1.1i brake calipers stuck
jsp
- x 12
Hi, I have one AX 1.1i from a relative and his brake calipers are stuck. I have cleaned the gliders but, still stuck.
My Citroens update:
http://www.frenchcarforum.co.uk/forum/v ... 14&t=50070
chinkostu
- x 30
Re: AX 1.1i brake calipers stuck
Piston stuck? The caliper design is crap tbh, 2 horrible pins to hold the pads in.
Does it not release properly?
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Saxo 1.1 East coast
1999 Punto
1996 306 1.8 XN Auto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
jsp
- x 12
not releasing properly
My Citroens update:
chinkostu
- x 30
Have you greased the sliders that hold it to the strut? Or just the pad retainers? I've found the retainers can rust a bit and pads get stuck. The only other things would be the piston not retracting due to crap in its bore or a brake hose thats collapsed so the fluid can't return.
Try opening the bleeder see if it spews fluid everywhere, that would point to a fault in the hoses or lines. Otherwise exercise the piston in and out (easiest way is to take the outer pad out and press the pedal to get full extention then pull the caliper against the inner pad to retract it)
Stu
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
Cars
2001 206 1.9 LX
2001 Saxo VTR
1999 Punto
1996 Fiesta 1.3
jsp
- x 12
yes sliders cleaned and greased.
My Citroens update:
van ordinaire
- (Donor 2017)
- x 402
Both flexis collapsing is unlikely - so I'd concentrate on the pistons. Like the use of the word "exercising" - 'cos you might need to do this several times. Would suggest once the piston's fully out, clean it with very fine wet & dry, preferably in paraffin, then lube with fluid.chinkostu wrote:Have you greased the sliders that hold it to the strut? Or just the pad retainers? I've found the retainers can rust a bit and pads get stuck. The only other things would be the piston not retracting due to crap in its bore or a brake hose thats collapsed so the fluid can't return.
Citroens:-
'81 2CV Club
'05 C15
'97 Xantia Exclusive estate
others:-
Jeep XJ Cherokees x 3
'96 Cadillac Eldorado
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
jsp
- x 12
replaced the caliper now and passed mot.
My Citroens update:
van ordinaire
- (Donor 2017)
- x 402
That's another way of dealing with the problem!
Citroens:-
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
'81 2CV Club
'05 C15
others:-
'99 Cadillac STS
