Problem speedometer after jump starting.
mlocky657
Unread post by mlocky657 »
Hi i have a 206 1.2 lx 1999 the battery went flat, the problem now is the speedo is starting from 30mph the rev counter is not working but when reving the car up the rev counter judders as if its stuck. But the fuel and temperature gauge are working perfect. Is there anyway i can reset the whole speedo or can anyone help in any way in pointing me in the right direction to getting this sorted thanks.
spider
x 77
Re: Problem speedometer after jump starting.
Unread post by spider »
You could try a full BSi reset to see if that helps initially.
I don't (think) they can do the 'jumping the pointer needle stop' trick on these.
Battery Disconnect / Reconnect Procedure
Procedure linked to is for Citroen but it is the same for Peugeot.
Andy.
mlocky657
thank you ill have a go tomorrow and report back. On the needle side of it I was told that you cannot. thanks
