HELP! can't get correct gear link rod for 1.6 16v petrol
jaydbass
New User
Unread post by jaydbass »
hoping someone on here can help or has experience of this issue. One of the smaller gear link rods has failed on my 2001 1.6 16v petrol model. I sourced the "correct" part from the local dealership - 2454 F5 - but it doesnt fit. The ends are 10mm and the ball joints on my linkage are 13mm on both ends. As far as i can tell, the linkage parts are original (unless the whole system was replaced with something non-standard when the car was virtually new...).
Dealers (both Citroen and Peugeot) have checked part listings for me but nothing has turned up. AEP were very helpful and checked a dozen or so different parts; but all had 10mm ends.
Has anyone come across this before? Is there a part of the same dimensions for another vehicle with 13mm ends i can source...?
Obviously i could replace more parts or the whole system - but I'm loathe to go to that expense when all i need is a £20 bit of meccano!
x 1480
Re: HELP! can't get correct gear link rod for 1.6 16v petrol
Welcome!
Dunno, can you post up the last 8 digits of the VIN, and a photo of the part? There are different parts for BE3 and MA gearboxes, but they all look to have a small and big end.
