Citroen C4 - Fault code p1536
lancia58
(Donor 2022)
x 8
Unread post by lancia58 »
Hi
My wife is a driving a Citroen C4 1.6 SX automatic ( AL4 ) . Lately from time to time the check engine is lit. Using a Lexia I found the p1536 fault code. Any one knows what can be the source for that fault
Zohar
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
Mandrake
x 697
Re: Citroen C4 - Fault code p1536
Unread post by Mandrake »
If you were using a Lexia there would be a description with the fault, not just a P number - what did it say ?
A quick Google suggests it might be "P1536 Parking Brake Switch Circuit Failure".
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
x 1061
Unread post by wheeler »
Does she drive it properly with one foot to do both pedals or does she drive it like a go kart & use one foot on each pedal ? I find that this fault often appears on autos when driven like a go kart, inevitably at some point the brake & accelerator pedals will be pushed at the same time & can log this fault.
Are the brake lights working as they should ?
jimmymarsbar
x 13
Unread post by jimmymarsbar »
P1536 relates to the braking system, as far as I am aware. And it depends on your engine type too - some models it's ESP, others it's parking/handbrake.
