Bought a Xsara Picasso 2.0 HDI exclusive.
The boot lock plays up, one minute it works then it won't, also at times when o unlock the car I hear the boot click open, is this common ? I have a petrol sx Picasso, will the lock from that fit, ones a 2000 reg. Others 2005, next time it opens I will give it a WD40 spray and see it that helps, but I noticed the hatch back button you push up don't have any movement like it does on my older one,
Look forward to hearing back
Thank you
Xsara Picasso
OnlinePaul-R
- x 1955
Re: Xsara Picasso
What did you do to fix it? Whatever it was it was a quick fix!
Ttwlr
Re: Xsara Picasso
Took it all apart and removed the switch, the nipple bit was a bit stiff and not popping up enough to reach the handle but that pushes it down to release lock, I gave to a soak in WD40,and pressed the nipple bit in and out a few times, put more WD40 on it and left it 10 mins, plugged in to test and worked, put everything back together and all is fine. Works perfect now
OnlinePaul-R
- x 1955
Re: Xsara Picasso
Good to know. I find that 3-in-1 oil in the spray cans works wonders on a host of hard to reach problems and, being an oil, doesn't evaporate like WD40.
Ttwlr
Re: Xsara Picasso
Good point that, I'll do that next time
