Hi
The front caliper started to leak , using Citroen part number 95667818 "FRONT BRAKE PISTON SEALING KIT" I want to rebuild it. If it was the rear caliper it was straight forward. The front caliper also has the handbrake leaver mechanism and it might be complicated. Any help is welcome .
Zohar
Xantia MK II - Rebuilding front caliper
lancia58
- x 8
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
lancia58
- x 8
Re: Xantia MK II - Rebuilding front caliper
Any ideas ?
Zohar
Zohar
- x 8363
The Handbrake mechanism does not complicate it Zohar, just wind the piston right out and then proceed with the overhaul...
Once the piston is out you can dismantle the handbrake mechanism if you wish but it's likely there will be no need to.
