Hi
Does anyone know if the ESP has a dedicated ECU ? If yes where is it located ?
C4 2009 - ESP ECU Location
lancia58
- x 8
Xantia 2.0 16V Automatic make year 2000 LHD
Citroen C4 THP Automatic make year 2009 LHD
Citroen C4 VTS 2.0 16V make year 2006 LHD
- x 6950
Re: C4 2009 - ESP ECU Location
According to the documentation, where the C4 is fitted with an ESP system, then there is no separate ABS ECU fitted. I think you'll find that the ABS/ESP ECU is actually incorporated on the Hydraulic brake block itself. You should be able to locate it following the brake pipes back to the unit. If you want the part for it, send me a PM with your VIN.
lancia58
- x 8
Hi Marc,
Found it using Citroen Service
Zohar
Zohar
OnlinePaul-R
- x 1955
Well done.
For the benefit of anyone else looking for it - where is it?
lancia58
- x 8
Hi
It is part 454939 "CENTRAL INERTIA UNIT" it is located left to the gear shift leaver ( LHD car ) . In some sites it is called ABS-ESP unit (https://bartebben.com/parts/citroen/dis ... len-1.html ).
Zohar
Zohar
- x 6950
I saw that part part but I think that is kiterally to monitor the inertia of the vehicle - but the the docs do say on the C4, where the ESP system is fitted there is no separate ESP ECU. Glad you found the right part whatever it's called!
- x 1504
That's not the ECU it's the Yaw sensor which tells the car which way it's pointing!
- x 6950
That's the ticket Richard - couldn't think of the word at the time!
